Another how to/will these fit?
I am looking into getting a custom set of wheels, and am trying to figure out what offsets to get. Here are the specs that I am looking at:
17 by 9.5 +49 Front
17 by 11 +49 Rear
Also would like recommendations for tires please. I am looking at a 275/40/17 for rear and maybe 245/40/17 for the front.
I can get higher offsets but I would like something that is somewhat aggressive. I will be dropped maybe 2 to 2.5 inches on Koni Yellows and Ground Control coilovers. I am going to get my fenders rolled and run some negative camber but I would like to know if that is all I need to do.
17 by 9.5 +49 Front
17 by 11 +49 Rear
You are going to need more than a fender roll with those specs. That rear is going to stick out 2" more than stock and that doesn't even take into account the increased tire width. I don't understand why you need such wide wheels when you won't be able to run tires to take advantage of them. If you only want a fender roll and negative camber I would be looking at something like 9" +50 front and 10" +55 rear.
What about:
17 by 9.5 +50 Front
17 by 11 +55 Rear
How would those fit? Unfortunately for 17 inch rims the widths are the only thing that can't be customized. They come in 9.5" then 11".
17 by 9.5 +50 Front
17 by 11 +55 Rear
those equate to 17x9 + 44 in the front and 17x9 +31 in the rear, you should be able to search around and find people with similar sizes. I am guessing you will need to roll your fenders + relocated bumper tab + run some less aggressive tires + camber... maybe 245/255 in the front and 265s in the rear
Or you could pull your fenders some and you could possibly run the size tires you want
According to an equation I found about S2000 wheel fitiments and offsets is that they can handle up to 8.5" of backspacing and 4.25" of frontspacing. From my calculations a 17 by 11 +49 would be 8" of backspacing and 4" of front spacing, so technically it should fit with some minor fender mods.
I believe he was responding to your second post. I think you could make that front work, probably need a higher offset in the rear if you are set on a 275/40. A 11" +70 would still stick out over 1" further than stock.
yep second post, just trying to make it easier for you, a lot of people on here have 17x9 +45 in the front, and some have either 17x9 +30 in the rear or 17x9 +35 (more popular)... that way you can get a good estimation of what kind of work you will need and what size tires people have been able to fit (although on a 9" rim)
I have seen multiple people with 17 by 10/10.5 with sub 40 offsets. I really would like an 11" wide rim. I talked with Dan at CCW and he told me that a 17 by 11 +58 would fit with just a roll and maybe -3 degrees of camber.
As far as the front I think I am going with a 17 by 9.5 +51.
Originally Posted by tsturbo,Apr 5 2010, 06:10 PM
Just curious as to why you want to go so wide? Looks? Seems to me you would diminish performance with that wide of tire.
