Am I rubbing?
Old 06-08-2006 | 07:09 PM
Kremlin's Avatar
Default Am I rubbing?
I bought a used S2k and twice now I've had problems with mysterious damage to front tires... The fronts are 18" Fikses /w 225 wide S-03s (lowered on Konis and Eibachs). Front passenger tire has some chunks of tread missing with a weird long slice down a lot of tread, driver's side has a similar slice now..
I was under the impression that rubbing generally caused damage to the fender, not the other way around. I'm kinda bummed that I just bought the car and I'm having this issue.
Old 06-08-2006 | 07:16 PM
04RioS2k's Avatar
you never mentioned the offset and widths of your wheels so we can't really tell if you're rubbing or not....
Old 06-08-2006 | 08:07 PM
jaxx4k's Avatar
sorrie to thread jack...
but will i rubb with 215/45/17 on 17x7 +42 offset????
lower bout same height as eibach springs.
Old 06-08-2006 | 08:50 PM
nj2tn's Avatar
If you have that long slice down the tire, you're rubbing. I had the same issue when i'd drop my civic all the way down.
Old 06-08-2006 | 09:25 PM
Kremlin's Avatar
Crap. What's causing that slice? I looked all over the fender well and can't find anything that fits that cut profile. I don't even own the stock suspension, raising it up a little to clear more is going to be difficult... Wonder if I can have the fender rolled out a little more to clear ok
Old 06-08-2006 | 09:32 PM
nj2tn's Avatar
That's got me thinking now. The fender inside seems to be a dull roll and not razor like. maybe put some chalk or somthing on the inside of the fender to see where it would rub.
Old 06-09-2006 | 09:24 AM
Kremlin's Avatar
18x8.5 Fikse FM-10s, +54 offset, 225/30/18 tires..
The damage to the tires is so weird looking and I can't figure out how the fender well could've done it..
Old 06-11-2006 | 01:25 AM
Project22a's Avatar
Hmm. Did your chunk/slice look anything like this?
If so, i had a similar problem on my Prelude. EXCEPT for my Prelude is stock height and on stock rims and stock sized tires.
Old 06-12-2006 | 03:51 PM
Kremlin's Avatar
No, sorry. The chunks missing on my tires are WAAAAAAAAAAAY bigger. Like, 4-5 BLOCKS of tread missing, then a slice that extends halfway around the tire.
Old 06-12-2006 | 05:46 PM
FormerH22a4's Avatar
If there is no visible damage to the fender or fender lining, perhaps it is just a crappy tire compound.
akrilic
02-19-2015 02:40 PM
ChuckV
05-28-2007 05:44 PM
TrIcKeD_oUt_s2K
02-07-2006 11:24 PM
C-IS
07-27-2005 10:42 AM
B SweepeR B6
04-01-2005 07:56 PM
