Am I going to rub?
Member
Spotter
Spotter
Id say you would probably rub if you are lowered. also 245/40 or 45? A simple roll should be sufficient
Im running a 225/45/17, 17 x 7.5 + 50 in the front with a 1.75 inch drop. I keep my dampers set at about medium hard and when I hit pot holes I used to rub the outer wall of the tire.
