Alignment: Tire Wear (Toe)
Old 05-06-2008 | 04:51 PM
mickey finn's Avatar
Default Alignment: Tire Wear (Toe)
This is an important question because I just obliterated a set of expensive rear RE01R's in 6000km (3750 mi.) due to very excessive toe-in. Please only answer if you're 100%.. no speculation please.. or at least make it based on experience.
My Honda user's manual shows that rear toe for 2005 (AP2) should be 0.15" (3.7 mm), which is roughly 5/32".
Is this the rear toe-in that should be dialed into each side (left & right), or is it the sum of left and rear toe? If it's the sum then each side should be dialed in at half of 5/32", namely 5/64" (0.078125").
When you get an alignment the technician prints a report for you and it shows the toe at each side, then it also shows the total toe, which is the sum of both sides.
Toe that is off by anything equal to or greater than 1/16" can speed up tire wear.. trust me.
My toe was set in equal on the right and the left at 1/4", bringing total toe to 1/2".
It's not even safe to drive with this much toe in because over bumps when one tire would lose contact with the ground the other tire would project the car along it's parallel; 1/4" into the car.
Let me know so I can get this guy to buy me new tires!
Old 05-07-2008 | 04:51 AM
No one knows for sure if the Honda rear toe specification in our user's manual (for AP2; AP1 is different) is 0.15" for each rear side, or 0.15" total, so 0.075" per side? (BTW, 0.15" is 5/32")
Toe is so important for tire wear (much more important than camber), that I thought more people would know.
Thanks again.
Old 05-07-2008 | 08:15 AM
Thanks again.
I just spoke with Honda and the TOTAL rear toe is 0.15" (3.7mm) or 5/32". So ideally you should aim to put half of this at each side, 0.075" at the rear left, and 0.075" at the rear right.
Old 05-09-2008 | 12:51 PM
moogleii's Avatar
Hmm, I just got my car aligned, and I was watching the screen while the tech was aligning it. 0.15" was in the middle of the "green zone" per tire. I'll have to check the print out when I get home, though.
It just seems weird that the other specs listed in the manual would be per tire, but not toe-in. Unless it's supposed to be 1.5 degrees of total rear camber...
Old 05-10-2008 | 09:20 AM
evolution's Avatar
What toe settings should I be using?
Lowered with kg/mm, running on 225/40/18 and 255/35/18.
HORRIBLE camber wear at the front. Fronts almost toast in 1000km. Mechanic did a test and the toe is wayyy off.
Old 05-10-2008 | 09:36 AM
Project22a's Avatar
@evolution: A lot of us here are running 0 toe up front.
S~Factor
01-18-2016 06:29 AM
RoninS2k
11-24-2012 08:32 PM
JUSTINTHECOASTIE
04-06-2012 11:48 AM
petouche
09-23-2005 12:00 PM
CMiS2K
51
06-10-2003 07:01 PM
Quick Reply: Alignment: Tire Wear (Toe)
