after upgrading what's the formula for determining tire pressure?
i'm thinking it's something like this...
if the OEM specs is
32 PSI @ 90 load index and max tire pressure of 50 PSI
and let's say I switch to a 90 load index and max pressure of 45 PSI then I should lower my pressure to maybe 30 PSI
this is correct?
what happens if the load indexes are different, so let's say my next load index is 92 and max 45 PSI.
i'm trying to see if there's some formula for translating the OEM specs to a new set of tires with different load index, max pressure.
thanks
if the OEM specs is
this is correct?
thanks
Former Sponsor
If the tires are going onto the same car the air pressure would be the same. It is not air volume it is air pressure you are measuring. The car stays the same and so would the air pressure.
Bones Applesauce
02-27-2009 05:15 AM
