Advan wheels
Advan wheels
Hi everyone I want to pull the trigger and buy either Advan RS or RZ in 17" on my "00 silverstone AP1, and plan on running F225/ R245 or 255...
Ive searched alot but am still not sure what offsets and sizes wont rub, Im at stock height and dont plan on lowering, rolling fender/relocating tab etc... Please help!!!
If you go with 225 fronts, go with 255 rears. 225/245 gives a bigfronts/littlerears look.
Tons of people will insist that you can rock +35 or less offset, but stick with +45 or more to avoid problems, and with +45s I'd probably stick with 215 front tires. Camber will help some, don't be shy about running upwards of -2degrees or more even.
Originally Posted by TrackStar,May 7 2010, 05:39 AM
Advan RS 17 x 8.5 + 50 fronts, 225 tire. Very flush with front fender but no rubbing. I'm lowered but not crazy low.
225s are a little stretched on an 8.5 inch rim, but when I burn through these, I'm going to try a 245. I have over fenders on the rear so I can't help you there. My front size should clear most bbks as they work on my Stoptechs.
I run Advan RS 17x9 +45 all around with a 225/255 tire setup. Before I dropped them on coilovers, I had no problems with rubbing on virgin fenders. Wheel gap is horrible imo, but it's your choice.
