Advan TC3
Advan TC3
Ok so I'm considering getting a set of advan tc3's and im not sure on fitment. Im usually good at this but im stumped. Im looking at 18×10 +35R 18×9 +25F. I know its a low offset for our cars so dont tell me the obvious. Will run DF wide fenders and ROF so my question is tire size and camber adjustment
With the tc2's I had on my car, which fit the same as these give or take 1-2mm, I had to run 215/45 up front 235/40 in the rear and -3 camber up front with -5 camber in the rear. I rubbed in the rear on big bumps and I pushed out my front fender a little exiting a driveway. And while on the highway the car felt like it was dancing around due to so much camber. Again this was all on stock body so youll most likely be able to run better alignment specs but that's my experience. I just sold them to get a more s2k friendly wheel.
Thanks. I like the wheel a lot but I needed to get another perspective from someone who has run them or similar sizes. I'm sure with the right modifications I could pull it off with no problems
redbaron
06-28-2011 04:26 AM
