Advan TC II about to make it's debut
I picked up some brand new Advans thanks to THMotorsports and I'm waiting on the last detail, tires. I'm completely stock body with roll and pull all around but I'm still skeptical on tire sizes. I know I'm going 215/45/17 in the front but I'm teetering on either 245/40/17 or 235/40/17 with the wheel being 17x9.5 +29. Any advice? I'm trying to stay less than 4 degrees camber in the rear and I'm also lowered right below fender to tire by maybe 1cm.
Site Moderator
Honestly that is the most relevant advise because you are going to have to roll the absolute crap out of you fenders and there still isn't any promise you won't damage them. You are looking at 4 degrees of camber and no way is a 245 fitting in the rear. To get these to fit right you should be doing downforce front fenders and rear over fenders.
I know there's a few guys on here that run those specs or equivalent such as x9 +22 or x10 +35. And I've seen them do it with a 235, but I didn't know if they were able to fit a 245 under there because there are more tire choices available with the 245.
