advan rg
advan rg
just wondering if the advan rg 17x9 with an offset of 45 will fit?? i am dropped close to 2 inches....
they do have a 17x8.5 with a 50 offset.. and i believe that will work.. but i want to go with a 9 width in the rear..
Originally Posted by bluesaint,Jan 5 2005, 05:51 PM
dropped by 2 inches? no you will not be able to run these unless you roll or cut your fenders.
i'm dropped by 1.5inches on my 17x8.5+54mm running 245/40/17 and it will rub under hard cornering. So of course yours will rub As to how much rolling you'll need depends on how much you rub. And i'm running 12kg spring rates in the rear too!
