Finally got around to ordering a set of center caps for my TC4s.
I ordered full flat for the front a flat for the rear.
I'm not 100% sure why the caps come adhesive but I put a little on per the instructions
To mount the wheels to the wall i used what you would find in the shed/garage section at home depot. When using the wall stud the hangers are rated at 75 lbs each. The hangers are long enough to securely hold the wheel. Ive had them mounted like this for at least a year.
Thank you so much for the reply. I know where I'll be headed on my next Home Depot trip.
I have a set of RZll on order. Same size except 45 offset. Vivid Racing says the new wheels should arrive just before the apocalypse.
Did you have to do any fender mods to make this fit without rubbing? I'm considering a similar set up. And also, do you know if the front would accommodate BBKs?
Either cap looks great.
For wheel hangers, yours works well because you can hang a complete wheel/tire setup. It'll also work if you're hanging only wheels, but these are another option as well:
