8x18 and 9x18 BBS LM - Tyres?
Old 08-31-2009 | 08:54 AM
OLLIeCRX's Avatar
Default 8x18 and 9x18 BBS LM - Tyres?
looking at buying these :
BBS LM
8x18 et40 (front)
9x18 et42 (rear)
what tyre sizes would be recomended? i`d really prefer not to roll and fender pull if i dont have to
thanks
Old 08-31-2009 | 11:19 AM
1nate7's Avatar
225/40, 255/35. A fender roll will probably be needed, especially if you are lowered.
Old 08-31-2009 | 12:13 PM
Mar48's Avatar
You may be able to get away without a roll... but that means you'll need a lot of camber + stretched tires. Also a very important question is what suspension are you running?
Old 08-31-2009 | 12:20 PM
OLLIeCRX's Avatar
ah! i forgot that bit, i`m running oem dampers with eibach springs.
if need be i can get the wheels milled up to 5mm if that will help adjust the offset to avoid having to roll.
its not that low on the eibachs
Old 08-31-2009 | 07:01 PM
RL1924's Avatar
I have the LM's in 18X9.5 +55 in the rear with a 255 tire. Now for some odd reason my drivers side sits about 3/4" lower than stock. The passenger side a stock height did not rub... Granted I had my fenders rolled before hand, but my drivers side rubbed even with a roll and I had to cut my fender tab. But I am also not running any -camber its same a stock.. If that helps at all lol
Old 09-16-2009 | 12:33 PM
OLLIeCRX's Avatar
just an update for future searchers.
on the rear i`m running a 225/40/18, slight stretch, no arch mods and no rubbing
currently the same on front with no rubbing, but i plan on changing to a 215/35/18 to give a bit of stretch with more arch room.
still running the eibach spring setup
Old 09-18-2009 | 08:39 AM
BerlinaBlackS2kguy's Avatar
Do you have any pics?
Old 09-19-2009 | 02:36 PM
114_ap2's Avatar
im running 225/35/18 up front with 18x8 +50 and 245/35/18 in the rears with 18x9.5 +55 for the rears and the rears rub alot.
Hasty
02-15-2015 03:20 PM
beelwin
02-12-2014 03:01 PM
cts206
03-11-2011 07:29 PM
module17
06-13-2009 11:13 AM
weak_sauce
10-11-2007 05:12 PM
