7.5 in the rear?
7.5 in the rear?
Anyone run 18x7.5 all the way around? Wondering if 7.5's in the rear will be too small.. not enough traction for the RWD? What're stock sizes? Thanks..
opinions on 18x7.5 in the rear.. +47
"Too small"? It's not our rims that are touching the ground. So, what you need to consider is the size of tire that will go on those rims. A 7.5" rim should be able to accommodate a 245 tire. With a 215 or 225 tire on the front, you should be OK.
That width and that offset should be fine. The OEM 17" rim is 8.5", +65 offset.
