5zigen fn01r-c fitment
Old 03-09-2015 | 10:49 PM
crxswap's Avatar
Default 5zigen fn01r-c fitment
Was wondering if 17x8 +38 all around would fit and what size tire.
Also what about 17x9 +38 all around?
Found a set for cheap and was wondering if they would fit. But he is unsure if offset is 38 or 43. Thanks in advance.
Old 03-10-2015 | 02:17 AM
jcconnox's Avatar
I'm no expert, but more than likely not without serious fender modification or flares. See here.
Old 03-10-2015 | 09:10 AM
Manga_Spawn's Avatar
Site Moderator
17x8 is to narrow in the rear. I run the 17x9 +43 (245 tire) in front and it needed a little fender pulling. The +38 would need more and more camber. It would fit the rear with a roll and a little camber. The best bet would be the 17x8 +38 in front and 17x9 +38 in the rear. If you want a square setup look for a set of 17x9 +43 all around.
I do have 2 17x9 +43 I would sell but they need to be refinished as they have curb rash and the finish is peeling off. PM me if you would be interested.
Old 03-12-2015 | 07:08 AM
manolo1492's Avatar
with the 17x9 +43 and 255/40 tire all around would you have to pull the fenders?? I've already had them rolled but the fronts looks very close, still haven't driven the car so figured I'd ask before tear stuff up
Old 03-12-2015 | 09:14 AM
Site Moderator
You may need to pull them a little bit. You could also just run a little more camber. If they are rolled there isn't anything for them to grab so it should still be fine.
SS Tony
04-18-2013 05:45 PM
nartnailuj
01-10-2012 11:30 PM
MickeyS
04-29-2010 06:04 PM
PilotSi
10-11-2007 08:21 AM
