5Zigen FN01R-c
Old 07-07-2008 | 06:34 AM
WyattH's Avatar
Default 5Zigen FN01R-c
17x7 +48 (no worries, this will fit), 17x8 +43 (this is where I'm concerned).
215/245 tires (AP2 sizes)
Mild fender rolling (no pulling or flaring).
UK-spec alignment (forget exactly, but about -1.2 deg front, -1.8 deg rear).
Suspension is Koni+RSR, so about 1'' drop F, 1.5'' R.
Will this still rub? Thanks
Old 07-07-2008 | 07:11 AM
1nate7's Avatar
You will be fine. You may not have to roll the fenders at all depending on how much negative camber you run.
Old 07-07-2008 | 06:38 PM
s2kbfast's Avatar
Speaking of FN01R-C's. Anyone out there got any 17 x10 +35's in Matt Black that they want to get rid of?
Old 07-07-2008 | 10:41 PM
WyattH's Avatar
That's crazy fitment.
I think I'll do +42 front and +43 rear, 215/245.
Worried about rear..
Old 07-07-2008 | 11:11 PM
AP2's Avatar
AP2
i think you should run a little more camber just to be safe. i know with an 8 +38 in the rear with a 245 a rubbed a little bit. as for the front, you should be fine.
Old 07-08-2008 | 06:41 AM
WyattH's Avatar
^ rubbed a little with what suspension and camber?
i dont want to go muchhhh past the UK spec. ill do a mild fender roll, too. rear dropped 1.5''.
Old 07-08-2008 | 05:04 PM
AP2's Avatar
AP2
at that time i had tanabe springs and US spec alignment.
Old 07-08-2008 | 07:43 PM
WyattH's Avatar
ah. so id be lower, with a tad more camber.
thanks!
Old 07-10-2008 | 07:03 PM
jimbrowski00's Avatar
I agree with ap2 here... you may want to run a bit more camber to avoid rubbing. The 8 inch wheel really wont give that tire any stretch and may bulge just a little bit. It could present some issues under hard compression.
If you rub, I would just relocate the bumper tab, but I'm not sure if your looking to do this.
jim
Old 07-19-2008 | 08:29 PM
JsnS2k's Avatar
Just bought drag wheels/tires for my MR2, so I took it's wheels and threw them on my S2k.
17x7 + 35 w/ 215 and 17x9 + 35 w/ 245
Sticks out some in the rear... Once lowered, and the fenders are rolled, it should actually look pretty good!
Quick Reply: 5Zigen FN01R-c
