5zigen FN01R-C ?
5zigen FN01R-C ?
i found this link through someone elses thread
http://www.wheelsdirectonline.com/5zigen/FN01RC.htm
was wondering if anyone uses these and in offsets 17x7 in the front and 17x 8 in the back was what i was planning on
if i were to run a 17x 7 all the way around what offsets would i want in the front and rear?
thanks guys
edit: I was thinking 17x 7 all the way around with 205/40/17 tires ...? sound like the right size tires? (maybe that helps with what offsets im going to need
thanks guys
There are no offsets given in the link you provided. You won't want to run 17x7s all the way around b/c you will lose the staggered front and rear. You could go 17x7 front and 17x8/9 rear given that they can supply the appropriate offsets. 205/40/17 is definitely not the appropriate size all the way around; too narrow in tread, too low in sidewall. You'd be looking for 215/45/17 f and 245/40/17 r.
