5 Zigen fno1r-c
Old 05-22-2015 | 03:29 PM
kslicks2k_85's Avatar
Default 5 Zigen fno1r-c
Alright so I have a staggered set of the 5 Zigens Hot Versions. Fronts are 17x7 35mm Rear are 17x8 35mm. I hit a curb a couple years back and I need to replace the wheel. As most of you know they are discontinued. However I found a single wheel only thing is is that its 17x8 25mm. Can I make this work with a spacer or anything? It will be a temporary set until I'm ready to by some more wheels. Any pros and cons for doing this thanks!
Old 05-22-2015 | 03:40 PM
Manga_Spawn's Avatar
Site Moderator
So you would use a spacer on the 17x8 +35? Because a spacer can only lower offset not increase it. In any case no it will not work or fit correctly. That is to low of an offset and sticks out 31mm further than a stock ap2 wheel. You would nee dto roll your fenders and run a lot of camber and likely a small tire for it to work.
A while ago another member was able to order from this site.
http://www.intensepower.com/5zigenfn01rc.html
You may try contacting them and seeing if they have anything in stock that matches your wheels or if you could buy 2 rear wheels.
Old 05-22-2015 | 05:09 PM
I have the 17x8 35 right now but I was looking at getting a replacement 17x8 25mm
Old 05-22-2015 | 05:23 PM
Site Moderator
Yes I understood that part but then you mentioned a spacer which I assume would be used on the 17x8 +35 to make it match the 17x8 +25. Did you read the rest of my post? Contact that site next week and see if they have a 17x8 +35 to replace the damaged one.
Old 05-22-2015 | 09:44 PM
Ok thanks
MSBx03
12-24-2018 01:29 PM
natlbar
11-13-2014 05:56 PM
Rodney
03-05-2008 07:09 AM
adidasvii
04-30-2007 08:46 AM
Quick Reply: 5 Zigen fno1r-c
