5 lbs lighter make a difference?
Old 01-19-2012 | 10:58 AM
2002 S2000's Avatar
Default 5 lbs lighter make a difference?
My 2002 has 17" 21 lb wheels on it. They were on the car when I bought and look very nice. I'm considering lighter wheels, possibly 16 or 17s. Will moving to a 16 lb wheel make the car respond and handle noticeably better? What else could I expect or is the $ better spent elsewhere?
Old 01-19-2012 | 11:01 AM
WhiteAP1ftw's Avatar
Reducing unsprung weight will make the car "faster" or "more responsive".
Not sure about handling though.
Old 01-19-2012 | 12:26 PM
deepbluejh's Avatar
It will theoretically hold the road better over uneven roads. You will also have a slight acceleration/braking advantage, though it's unlikely you'll notice it.
Old 01-19-2012 | 12:53 PM
2002 S2000's Avatar
I was hoping that a 5 lb reduction per wheel would be noticeable in acceleration too. But if not I may do a cat back and high flow cat or test pipe. I like the design of the 17" wheels but 21 lbs certainly isn't light.
Old 01-19-2012 | 01:26 PM
RedCelica's Avatar
They do make 16lb 17" wheels ya know I think it mostly help with braking if anything. Rotating mass is the hardest to accelerate/decelerate so it makes sense that it does more than just "lighten the car up."
Old 01-19-2012 | 01:46 PM
starchland's Avatar
keep in mind also where the weight sits on a wheel will also make a difference. a 17" package will put more of the rotating mass on the outside of wheel, not to mention the heavier tire too
Old 01-19-2012 | 02:12 PM
newyawkballa's Avatar
Banned
Believe it or not, but the 255-35-18 Hankook Rs-3 tires weigh 25lbs, compared with 26lbs for rear 16" OEM Ap1 Bridgestones. It seems the more low profile a tire is, the lighter it is. My 18" SSr Type C rear wheel and tire package is 2-3 lbs lighter per side. A lot of 18" tires are actually LIGHTER then 16 or 17" tires. Food for thought.
Old 01-19-2012 | 02:19 PM
TTMartin's Avatar
You'll lose a lot more performance (handling) by going with the taller sidewall of 16" tires than you will gain in weight savings.
Old 01-19-2012 | 02:56 PM
Jphoa's Avatar
Werd.
My 255/35/18 star specs weigh just a tad less than my 255/40/17 rs-3s...
Old 01-19-2012 | 03:00 PM
Mar48's Avatar
Some quality coilovers will make the car handle better while improving the look... Also, grippier tires will improve handling noticeably.
It wouldn't be a bad idea to save up for some quality forged wheels - it may not be as noticeable but will help especially when paired with other mods.
I think a couple really light quality wheels are SSR Type C's (they are 14-17 lbs a piece) and most Volks (usually around 15-18 lbs)
