350z rims on an s2000?
Originally Posted by Nismofan,Jun 20 2010, 06:46 PM
I've wanted to see the old track wheels on the s2000. Bore out the hubs and you're good to go, but nobody has tried that
The ones you are looking at are 8" +30, it can work will rolled fenders and negative camber. You will need to bore them out to fit over the front hub as Nismofan mentioned. They are very heavy, around 25 lbs.
Originally Posted by s2papi,Jun 21 2010, 07:54 AM
how much will these negative cambers cost?
Camber is an alignment setting. If you are looking at the car from behind, negative camber would make the tires look like this /------\. It helps tuck in the top of the tire so it doesn't rub when the suspension is compressed.
Honestly, I wouldn't run those wheels even if they are free. You would be much better off with a set of stock AP2 wheels or something.
