265/35/18 9.5" +42
265/35/18 9.5" +42
Hey guys,
I'm looking for a bit of advice. My wheels specs are below, and I'd like to know if a 245/35/18 front and 265/35/18 rear tire setup would be feasible. I've done the math and, in my head, I think everything should fit alright. Tire diameter is relatively close to stock as well with this sidewall measurement.
18x8.5 +47
18x9.5 +42
The car will be lowered 1.5" to 2" with close to -2.5 to -3 degrees of camber, which I consider acceptable/functional.
Also, there seems to be a decent selection of tires with a 300 tread wear rating in these sizes, although not many in the 200 TW rating. Any suggestions there? I know of the Falken Azenis, but they are pretty pricey, especially in 18" sizes.
I am aware that my rear quarters will essentially need to be rolled flat or even trimmed, and that the fronts will have to also be rolled/trimmed and possibly flared slightly, although the front sizes are a good bit less aggressive than the popular 17x9 +45 255/40 size, which should afford some more fender clearance
18x8.5 +47
18x9.5 +42
No need flare the fronts. Just do the typical fender rolling and the 245 will fit fine up front with -2.5. Id look at the manufactures size spec for the 265 and compare that with a typical 255/40/17 extreme summer to see if there are any width differences between he two and if so how much in which direction, because really anything wider then the 255/40/17 and your going to face a challenge with that offset and width and not going more then -3 on the camber, which I definitely would not. and -2.5 is better.
255/35/18 comes in at 222mm tread width
265/30/19 comes in at 238mm tread width
So roughly 16mm wider from a 255 to a 265. Making the outer clearance 8mm more aggressive. The chart I found did show the same tread width for a 225 in a few different sidewall heights and wheel diameters so this should be accurate info.
Considering the common 17x9 +45 255 setup again, that would make the outer clearance of my wheels with the 265 about 11mm MORE aggressive (8mm accounting for the tire and 3mm accounting for the change in offset)
Since the 9" +45 is pretty easy to fit the 255 in the rear, and I have seen a 9" +35 with a 255 done, I think I should be alright.
FWIW, i have a 265 RE760 on my 9.5 for my daily and it is ever so slightly stretched. but the 245/40 i have up front on the 8.5 sits much fatter. both are 18" and the 760s are 300 treadware. but yeah, if you are just starting, id recommend a 255/35/18
I see the offset of the wheels in your sig, which means you must have some sort of overfender. Really the one reason I wanted the 265 in the rear was so that the sidewall profile would more closely match the front so I appreciate the feedback about that.
