255's on OEM AP2 Front Rims?
AutoX stock class setup states that some guys are running 275's !!! on all four corners. I find this hard to believe. Those are R-comps of course. Is there any problem with running 255's on the front? I realize it may not be optimal performance, but I picked up 8 255 Star Specs and I'd like to use them without having to buy rims I know stock class guys mount 245 R-Comps on front for sure, but I was surprised to see the Stock Class AutoX setup thread state that 275's have been used all the way around. Let me know your thoughts! thx!
Tom
Tom
The problem with AP2 rear rims on the front is the bore. You have to get it drilled out to accommodate 70mm. I'm just looking to use the tires I have on the rims I have. I know running tires outside the recommended rim width range is being done by stock class autocrossers - but those are r-comps. Does that make it any safer than running outside the rim width range on street tires? (I'm not worried about classing right now. Just competing locally in clubs)
