255s all around
255s all around
I just purchased a set of AP2 rear rims and had them machined to fit on the front. I am currently running 255s on the rear and would like to run them on the front also. There is currently 1.75 degrees of negative camber on the front and the car is lowered about 1.25 inches. Will this work on the front or will I need to get the fender rolled? Would I be able to put 275 on as well?
Thanks for any help, Rich
They should fit fine... and you'll probably find that you'll want a little more camber up front for performance purposes. This will also increase wheel to fender clearance as an additional benefit. At the most you may need a very slight fender roll, but I doubt it.
Former Sponsor
You are also going to want to play with air pressures to tune the handling. A front sway bar would also be a good thing to look at.
If I can help with the tires let me know.
