255/50/16s on stock wheels?
hey i was just wondering if anyone is running 255/50/16 on the stock rear wheels? if so what do you think? and which tires are you running? thanks
Former Sponsor
Why would you want to run a tire that is over an inch taller on the back of the car? While it will fit on the wheel I would not recommend it for the car. I am sure you would throw off the handling and the anti lock brakes.
245/45/16 maintains the same rolling radius as the stock tires.
255/50/16 is a significantly larger tire than stock. The only Max Perf tire in that size is the Michelin Pilot Sport for $236 a pop. It's overall diameter is 23" [edit - it's actually 26"], compared to the stock tire's 24.8" diameter.
In other words, don't do it. Get the 245/45 instead.
s2kboy03
02-25-2005 10:43 AM
