245s 17s all around?
Old 11-03-2010, 09:32 AM
lilmrtinnie's Avatar
ok here are sum pictures of how much room i have
on stock ap2v1s this is my room after -2 camber in the front, thats with 215 45 17
on 245 40 17s with stock ap2v3 rears put on the front... i dont have a good picture yet, i'll update tonight
any suggestions? i have alot of room with the ap2 wheels up front
Old 11-03-2010, 09:37 AM
o ya another reason i want to run 245 40 17 in the front is because i feel like 45s might rub extra hard
Old 11-03-2010, 10:13 AM
1nate7's Avatar
IMO, it doesn't make sense to run non-staggered tires on staggered wheels. I think you would be better off sticking with 225/45 front and 255/40 rear for both fitment and performance reasons based on your wheel width/offset.
Old 11-03-2010, 11:11 AM
yes its true, but in order to run 245 in the front your going to run negative camber, so why not go a little bit more stagger, not crazy stagger but just a tad. I also like to order 4x 245 40 17 sumitomos at once haha just IMO i guess.
ZDan's Avatar
If you rubbed a little with OEM AP2 rear wheels up front, how much do you think you're going to rub with the tire shoved another 37mm (65mm - 28mm), or 1 1/2" further outboard?!
Old 11-03-2010, 11:22 AM
when i had the same +28 setup on 215 tires with -1.5 camber it never rubs and it still look sunk, so i was just tryna get opinions about upgrading to 245 in the front. I'll update soon, getting the tires on probli today or tomorrow, hopefully it can help some others trying to run this setup too.
Old 11-03-2010, 11:23 AM
when i make a hard left turn, passenger side rubs just a tiny tad with the 245 stock rears on the front
Old 11-03-2010, 02:21 PM
corn fed's Avatar
255/40 will fit in the front with a 9" +45
camber will be between -2 or higher depending on your fenders
Old 11-03-2010, 04:44 PM
ZDan's Avatar
If 245's rub a tiny bit on stock AP2 rims, what do you think shoving the tires outboard more than an inch will do? If you're talking about AP2 rears mounted up front, those have +65 offset. +28 offset will move the tire more like 1 1/2" outboard. That is a HUGE amount!
Old 11-03-2010, 06:42 PM
JDMQuip's Avatar
I see this guy posting in the 'I cheesed up my fenders' thread in a couple weeks.
Quick Reply: 245s 17s all around?
