245s 17s all around?
How many of you guys run 245 fronts and 245 rears all 17s? how do you like it? with -2 camber up front would it be too much? what about on track days, cons and pros? sorry for the million questions, but im just really leaning towards this setup. Thanks in advance.
i have 17x8 +28 in the front, 17x9 +35 in the rear, not really aggressive. -4 camber in the rear -2 in the front, all 4 fenders are rolled. The thing is i dunno how bad it is going to oversteer, or like how it will feel at all
I'm running 17x9 +45 all the way around, with 245's. ya the car does like to oversteer a little bit. You'll adjust to it. But I plan on goin back to staggered once I use up these tires.
-2 camber in the front -3 camber in the rear.
I think you're going to have a hard time fitting 245s up front with only rolled fenders.
well i fit stock rear tire ap2v3s on my fronts before with 245, it barly rubs only if i make a left at around 30+, im not sure if the x8s +28 will make that big of a difference
+55mm - 28mm = 27mm, over an INCH of difference!
