245/50/16 on rear affect ABS?
i'm running stock 205/55/16 on the front right now and my rear were 245/50/16
kumho ecsta asx and i'm in need of another set of rears right now. I'm thinking of running the same size again or should i downgrade to 225/50/16 and get my ABS on the right course again. When i was running 245/50/16 I didn't really feel the ABS going crazy but then again I didn't do anything really crazy.
There is not much choice available in 245/45/16. Like the sticky says you really want to stay with 245s on the rear if you're getting non-OEM.
I got 245/50/16 installed recently after a few members recommended it and its a marked improvement from 225/50/16 that the previous owner had installed.
rijowysock, 225s in the front and 245s in the rear doesn't sound like the right setup either.
mayeb you dont know me but i know my tires
widest rear made for 16=245
oem 205/225
so u bump to 225/245 when ur not buying so2 because s02's run wide
225/50.16=25" diamater=same as oem
245/45.16=25" diameter=same as oem
w/ 245/50.16 ur tire is too big diameter wise 25.7
so... 3.9% too slow compared to oem sizing
meaning when your speedo says 60mph your actually going 62.3mph
whereas with 245/45 when ur speedo says 60 your going 60
oem 205/225
yoko avs es 100?
www.tires.com
www.tirerack.com
search the size 245/45 first pretty much every one of those comes 225/50 as well. idk about all season.,. i run summer tires all year here. sorry
www.tires.com
www.tirerack.com
the reason why i'm not running 245/45/16 is b/c its not available in kumho ecsta asx and thats currently my setup right now. Since the rear is bald i only want to replace the rear only and with the same type of tire so it wont affect my handling.
