245/40/18 rears
Old 06-21-2010 | 09:30 AM
lzybum's Avatar
Default 245/40/18 rears
apart from it being off the speedo and the sidewalls a bit tall, is there anything wrong with running 245/40/18 on the rears? possible braking failure etc... ?
according to tire calcs, its like an 25mm increase in rolling diameter when compared to ap1 size (R:225/50/16?).
Old 06-22-2010 | 02:19 AM
lzybum's Avatar
anyone?
Old 06-23-2010 | 12:50 AM
alexisthemovie's Avatar
Nothing, I am running 245/40/18 all around right now on 18x9.5's and they feel great.
Old 06-23-2010 | 06:39 AM
//steve\\'s Avatar
It's a tall tire but you'll be fine. Just watch your speed. At highway speeds you'll easily be going 5+ mph faster than your speedo says. If you normally drive fast sometimes that's just enough to get you pulled for speeding when you don't think you are.
Old 06-23-2010 | 07:28 AM
[DT]'s Avatar
What size (width) wheel? If you're running a 9" or wider, I'd go with a 255 in a 35 profile. That's what I'm running with a 225/40 front.
Old 06-23-2010 | 01:56 PM
Jim@tirerack's Avatar
Former Sponsor
There is something wrong with that size. They are taller than the OE tires and will throw off the speedometer, odometer and gear ration. With the 225/40R18 on the front and the 245/40R18 rear you can also mess up the anti lock brakes.
Old 06-24-2010 | 04:04 AM
lzybum's Avatar
if it means anything,
im running 17/18 combo
F: 215/45/17 on 9"
R: 235/40/18 over 9.5"
and want to run if possible R: 245/40/18"
i didnt want to increase the width for the front as i want clearance for my fenders and didnt want to go down on profile as i dont want to lower the car anymore to fill in the wheelgaps.
with 235/40/18's the sidewall looked a tad shorter than 215/45 which is why im asking about 245/40/18's instead.
any possible recommendations for some 17/18 combo tires?
Old 06-25-2010 | 10:47 AM
Rubn1out4GudLuk's Avatar
Originally Posted by [DT
,Jun 23 2010, 07:28 AM] What size (width) wheel? If you're running a 9" or wider, I'd go with a 255 in a 35 profile. That's what I'm running with a 225/40 front.
s2kev
01-17-2012 05:49 AM
DesiS2k
02-04-2011 06:31 AM
module17
04-19-2009 02:43 PM
bliss at 9k
02-19-2008 11:40 AM
fpdok2
10-13-2004 01:34 PM
