245/40 17's in the Rears, Lowered 1 inch --> Rubbing inevitable?
Old 12-13-2001 | 07:56 PM
Psicho54's Avatar
Default 245/40 17's in the Rears, Lowered 1 inch --> Rubbing inevitable?
This is the setup I'm thinking about going with on 17x8's in the rear that have 45mm offsets. Is this gonna rub like crazy or what? Anyone with the same setup?
Old 12-14-2001 | 09:32 AM
Phantom's Avatar
Depends on how much your car is dropped, if you are over 200lb, and if your passenger is over 200lb.
Old 12-14-2001 | 09:37 AM
Psicho54's Avatar
What if I lower the car 1-inch, and I'm wavering at around 160 lbs ... and hopefully the girl sitting in the passenger side doesn't weigh 200lbs ... no rubbing?
Old 12-15-2001 | 05:27 AM
Scot's Avatar
my 17*8.5 volks didnt rub even with the Nuespeed springs which dropped the car over 1". My offset in the rear was 50mm and i ran 245/40/17's
hope that helps... i weigh 175lbs but even with a trunk full of beer for S2k Asheville thing no rubbing.
Old 12-15-2001 | 10:47 AM
RT's Avatar
RT
[QUOTE]Originally posted by Psicho54
[B]This is the setup I'm thinking about going with on 17x8's in the rear that have 45mm offsets.
Old 12-15-2001 | 05:30 PM
Psicho54's Avatar
[QUOTE]Originally posted by RT
[B]
It'll rub, but not like crazy.
Old 12-16-2001 | 01:57 AM
RT's Avatar
RT
[B]
Yea, they are 17x7 and 17x8 with 45mm offsets.
Old 12-16-2001 | 10:27 PM
Psicho54's Avatar
I just installed the wheels ... basically from a bird's eye view looking down, the tire sticks literally about 1-2mm out in the front and back ... I like the wheels a lot, so I think the couple mm's of tire is ok for me to accept. Yes, it would be REALLY nice if the offsets were larger, but I'm satisfied with the look. I think perhaps lowering the car (no more than an inch, probably less) would make the wheels look more "inner", but MIGHT cause some rubbing because of the lowered height. It's something I'll have to think about though. I love the wheels though!
By the way RT, you are the king of wheels/tires as far as I'm concerned. You know too much about this stuff.
Old 12-16-2001 | 11:23 PM
RT's Avatar
RT
[B]I just installed the wheels ... basically from a bird's eye view looking down, the tire sticks literally about 1-2mm out in the front and back ... I like the wheels a lot, so I think the couple mm's of tire is ok for me to accept.
Old 12-17-2001 | 08:04 AM
Psicho54's Avatar
[B]
Glad they worked out for you, treat us to quick picture of your ride will you?
