235/45/17 Rubbing in Front
Old 07-14-2010 | 02:20 PM
jadebellyt's Avatar
Default 235/45/17 Rubbing in Front
Hey guys,
Had a question for you all. I bought 235/45/17 Khumo XS tires for stock wheels up front on recommendation from an AutoX buddy of mine. He claimed 235s fit up front without modification, and so I happily bought a set to help with front end grip during my autox events.
But I recently installed them and they ride fine until pushed. Now in hard corners, I hear rubbing. I think it's rubbing on the fender liner. The car is completely stock. Has anyone else had the same problem with 235s on a stock S2k? And will this cause any adverse problems to the car during autox? Thanks!
Old 07-14-2010 | 04:00 PM
ZDan's Avatar
235/40-17 is a much better size to go with. 235/45-17 is taller than stock, 235/40-17 is shorter than stock, much less likely to rub.
Old 07-14-2010 | 05:41 PM
jadebellyt's Avatar
Sounds like a plan, but the Khumos didn't come in 235/40-17
Old 07-14-2010 | 06:56 PM
ZDan's Avatar
If no 235/40-17 were available, I'd probably try 245/40-17 (24.7" OD) before 235/45-17 (25.4" OD).
What's your camber?
Old 07-14-2010 | 07:14 PM
1nate7's Avatar
If you are on 7" stock wheels then I wouldn't go any wider than 225.
Old 07-15-2010 | 12:52 AM
Dschultz's Avatar
Yeah i just got some 17 x 9 with 63mm offset from 949 Racing, theywheels are awesome. I tried to get 255/40 all the way around, didn't happen. Tomorrow I am having them put 245/40 or 235/40. Will this mess up the abs or vsc? And what about the tire pressure sensors, is there anyway to disable them?
Old 07-24-2010 | 03:31 AM
Shibikku's Avatar
Dschultz: what was your result with 235 or 245s in the front?
thanks!
chris S2000
06-17-2011 10:51 AM
Duyx817
03-29-2011 09:22 AM
jadebellyt
07-15-2010 11:12 AM
psychophd
09-02-2009 11:12 AM
Idyfohu
10-28-2005 04:28 PM
