235/245 set up?
235/245 set up?
i recently just bought rear tires 245/35/19. i was running 225(70% tread more wore in the inside from lowering) in front but thinking i should now replace the fronts too??, but to match the rear tires i would have to get 235, (they dont make 225) would this work? what kind of problems could this cause? Or should i just hold out and wait till they both wear out and get 235/255?
Former Sponsor
The handling will not be the same as stock because of the difference in the stagger front to rear. I would think the 225 in the front would be better but if you end up with different tires front to rear that is not a good thing either.
