235 or 225
Old 01-07-2008 | 12:22 AM
chairmnofthboard's Avatar
Default 235 or 225
I got some RPF1's (8" & 9") I'm getting REO1R's. I'm getting 255's for the rear. but can't make up up my mind for the front.
My options are:
215/45/17-stretched, so this wont work.
225/45/17-will work, but seems too big in diameter.
235/40/17-I'm not sure about, I think it might have the same diameter as 225/45/17.
I've had 225/45/17's in the front before, it was a bigger diameter than the stock rear tires. I hated it, that's really what I'm trying to avoid.
what do you guys think?
Old 01-07-2008 | 08:51 AM
I got some info, but I would like to see others input.
Old 01-07-2008 | 10:06 AM
Suspension's Avatar
Uh, the 225/45-17 is a slightly larger diameter than the stock 215/45 but is the exact same diameter as your rear 255/40-17. I would go with the 225. The 235/40 will be a slightly smaller diameter, even smaller than the stock 215/45. Diameters from TireRack:
215/45-17 24.6"
225/45-17 25.0"
235/40-17 24.4"
255/40-17 25.0"
And the width of the 235 with the RPF1 offset is going to be very close to the front fenders.
Old 01-07-2008 | 10:35 AM
huy@logic's Avatar
Old 01-07-2008 | 11:00 AM
TeKNiC330's Avatar
Originally Posted by huy@logic,Jan 7 2008, 10:35 AM
225/40.
I think that would be too short in terms of overall diameter.
Old 01-07-2008 | 11:30 AM
revmatch's Avatar
Old 01-07-2008 | 11:55 AM
silentdancer's Avatar
225 but be careful if u havent rolled your front fenders
Old 01-07-2008 | 03:23 PM
225/40.
that's what I wanted originally, but REO1R's dont come in that size. Only Hooser R compound race tires.
So you think 235 might be a bit much. To close to the fender.
Old 01-07-2008 | 03:50 PM
ZeroPsi's Avatar
even at stock height? (I do auto-x the car so it will be leaning pretty hard) Just curious as I just put those 225/45/17's on my car and will be attending an autox soon.
EDIT: just saw that this was on rpf1's, my mistake.
Thanks for any help
Old 01-07-2008 | 04:22 PM
My car is on Tanabe springs, so it about an .8"-1" lower.
