225/50/16 and 255/50/16
hey guys im looking for some new tires and i like the toyo RA-1 radial....will this setup mess with me any? like fitment or any general things
front 225/50/16
rear 255/50/16
front 225/50/16
rear 255/50/16
You do know the RA-1 is a race tire right? They can be run on the street and are considered by most the best "streetable" R compound so that's cool as long as you're aware. As for sizes the 255 is nearly an 1.5 inches taller than stock so I would not recommend them. The 205/245 combo is much better and will have plenty of grip as well as fill up the wheel well because they are wider than the specs dictate. I run this config at the track as well as many others. Good luck!!
1 Post
Originally Posted by BigSkinnyS2k,May 10 2005, 11:13 PM
you think 225/245 is good i know a lot of guys on here run that setup...
1 Post
Originally Posted by TubeDriver,May 11 2005, 09:48 AM
225/245 works for people running AS Solo II WITH a larger front swaybar. If you are running on the street with OEM swaybar you want a 205/245 combo.
I too run the 205/55-16 and 245/45-16 on the track and it is a wonderful set up.
It sounds like the RA1s have pretty good life for the street (I know ppl have raved about their life on the track). Anyone know how the A032R H-compound wear on the street?...would they last fairly long (similar to RA1). They also come in the correct 205/245 setup. Thanks.
so what with it effect if i get the 225/50/16 in front and 245/45/16 in the rear without bigger sways..i mean is it going to kill me if i dont have sways
right now im running 205 front with 225 backs (s03's not s02s) which should make the car more prone to oversteer, but i drive the car at the limit regularly and If anything i still think the car understeers a little more than it oversteers.
1 Post
1 Post
Th fact is, your current setup has less wide of a tire in the rear compared to the OEM setup (OEM S02 225 is really closer to 245 in size). I don't see any good reason to run a narrower tire in the rear.
