20mm / 25mm spacers
Old 02-23-2010, 11:06 AM
1nate7's Avatar
Originally Posted by CourageOO7,Feb 23 2010, 11:02 AM
Is it possible to run a 10mm rear spacer on the factory studs?
No, 5mm max and even that is pushing it. You lose 2 full turns of a lug nut with only a 3mm spacer (wheel stud thread pitch is 1.5mm) which is the widest I would run on stock studs.
Old 02-23-2010, 11:11 AM
CourageOO7's Avatar
Okay. Well, do H&R (or Kics or Ichiba) 15mm rear spacers with the studs require you to cut down the factory studs? I don't understand how you can run a spacer narrow than the width of the factory stud.
Old 02-23-2010, 11:24 AM
1nate7's Avatar
It entirely depends on the wheel you are running. Most aftermarket wheels have a recess there that will allow clearance for the stock studs. I believe AP2 wheels have at least a little clearance, should work with 20mm spacers and possibly 15mm.
Old 02-23-2010, 11:26 AM
CourageOO7's Avatar
I'm paranoid. I'm running the race version of the CCW Classics and they have holes cut for this exact reason, all the way through the wheel. Helps to take a closer look at when you run. Sweet. lol
Old 02-23-2010, 01:32 PM
adrs2k's Avatar
Does H&R make a 20mm spacer with built in studs? I have not been able to find anything.
Old 02-23-2010, 07:11 PM
1nate7's Avatar
Yes, #4065700 and #4065640. Make sure they are DRM style, that is the bolt on kind.
Link is for reference only: http://www.lpiracing.com/Honda-S2000-H-R-W...-9285p28046.htm
Old 02-23-2010, 07:25 PM
adrs2k's Avatar
Sweet thank you. I think I will end up giving the 20mm on all four a try. I am already at -1.5 camber front, and -2.0 rear.
Old 02-28-2010, 02:56 PM
fishs2000's Avatar
Originally Posted by ILoveMYHonda1984,Feb 22 2010, 08:51 PM
I have project kics 25mm front and rear on V2s w falken azenis 215/255 combo. Lowered pretty far on bilstein pss9 with -1.5 f and -2.5 rear camber. Not much rubbing to speak of, not rolled or anything. Looks absolutely sick!
ya man, i would like to see pics if you could post?
jmardis
06-26-2015 05:58 PM
jetguy
03-07-2014 03:28 PM
boiii4
11-09-2009 05:05 PM
Quick Reply: 20mm / 25mm spacers
