20mm / 25mm spacers
20mm / 25mm spacers
Ive found a little misleading and confusing information about hubcentric spacers with integrated studs.
Can anyone tell me who makes, with part #, hubcentric 20mm and 25mm spacers with integrated studs?
Thank you,
Thank you,
H&R 25mm #5065700, #5065640. If you get 20mm, make sure your wheel has the proper recess on the back to fit over the stock studs because the spacer won't completely cover them.
You need 70.1 mm bore for the front, 64.1 mm for the rear.
Nate - do those part numbers come with the nuts for the existing studs as well? and the tool to tighten them? Or do those have to be ordered seperately?
Thanks guys. :thumbsup:
Are the hubcentric spacers even needed? Guess its a matter of opinion. I have heard yes and no.
I am looking into 15mm and 20mm spacers. I run 225/255 tire setup, and will be getting coilovers soon. Currently running the UK alignment. I am planning on rolling my fenders as well. Do you recommend the project kics spacers? I wanted to run H&R spacers, but I do not want to press new extended studs and all that goes with that job.
Anyone running the 225/255 with 20mm spacers all around and lowered on AP2 V1's?
I have project kics 25mm front and rear on V2s w falken azenis 215/255 combo. Lowered pretty far on bilstein pss9 with -1.5 f and -2.5 rear camber. Not much rubbing to speak of, not rolled or anything. Looks absolutely sick!
Nice, ya got any pics? If I decide to just keep my oem wheels for another 6 months to a year, I am def thinking of doing 20mm on all four corners, with 225/255. Not lowered yet, but I won't be slamming the car, but a little bit of tucking is what I am shooting for. Planning on doing a full roll as well.
