2006 OEM Wheels and BREMBO BBK...
well. i have my wheels with custom offsets on order to fit this kit, but i was wondering if for the mean time i could use the stock wheels with spacers? if so what size spacer would i need? thanks..
also.. the brembo's ARE lighter than stock brakes. 1lbs. per caliper and 3 lbs. per rotor.
Originally Posted by AP2_S2K,Sep 1 2006, 06:31 PM
You could maybe take the wheel off, put the caliper on the disc and lay it against the inside of the wheel, see how much you'll need. Since the wheel does mount against the hat.
