2 Work Wheel Offset Choices Help ASAP
Old 03-30-2006, 02:21 PM
IIGQ4U's Avatar
Default 2 Work Wheel Offset Choices Help ASAP
Hi,
I am going to purchase a set of Work Meister S2R wheels and I need some assistance deciding between two offsets.
For the fronts, the sizes/offsets that I am thinking about are:
17x7.5 +48
17x7.5 +59
For the rear, I am looking at:
17x9 +55
17x9+73
I appreciate any help that you all can provide.
Old 03-30-2006, 03:10 PM
spa-zz's Avatar
Always get the higher offsets when working with an S2000 unless you are trying to clear a BBK.
That said, you could use the lower offsets with a 215/245 tire combo, or even 225/255 if you are feeling lucky. The higher offsets would let you use even wider tires than that.
Old 03-30-2006, 03:13 PM
IIGQ4U's Avatar
Sweet!! Thank you so much bro!!! +59 and +73 it is!!!
Old 03-30-2006, 04:02 PM
carloS2000's Avatar
After talking with the Work distributor in Costa Mesa, and an independent Work dealer, I wound up ordering 17x8 .51 front, 17x9 .63 rear, 225/255 Advan Neovo. Did I do the wrong thing?
Old 03-30-2006, 04:04 PM
carloS2000's Avatar
Forgot mention: Meister S2R wheels, stock suspension
Old 03-30-2006, 04:14 PM
rijowysock's Avatar
goodluck clearing rear suspension and inside wall.
higher is not always better
Old 03-30-2006, 04:46 PM
tru
tru's Avatar
im runnng 63 offset in the rear and 265 tire with minor rubbing on big dips gotta go double check my front offset
Old 03-30-2006, 05:51 PM
CrazyCracker82's Avatar
i have 18x8's and 18x9's but my offset in the front is +51 amd the rear is +60. the offset is perfect! i can tuck the rears if i want easy and will only rub if you hit a large bump at over 40mph
Old 03-30-2006, 06:26 PM
carloS2000's Avatar
Thanks guys, I appreeciate the feedback. I'm not car stupid but I have to admit that offset confuses me. I drive my car aggressively on Coast Highway 1 - when safe - and there are lots of dips & bumps. I specifically told these guys that I wanted a "real world" setup and that's what they recommended. Should I cancel order?
Old 03-30-2006, 07:26 PM
IIGQ4U's Avatar
Are you referring to me? If so, then what ofset do you recommend? I will be riding on KW Variant 3 coilovers and dropping my ride a bit.
Quick Reply: 2 Work Wheel Offset Choices Help ASAP
