18x9.5 +6 Back Flares!
I'd run 150mm just to be safe.
Shouldn't this question be "What is the smallest flare required?" You would need ~50mm extra clearance to answer your question. IMO anything over 25mm isn't really a "flare", you are in widebody territory. I would highly recommend reconsidering your wheel specs.
If you ran a 205 tire and rolled the fender flat + a little pull, you could probably fit them with -8 degrees of camber. If you pull the fenders using the phone book method, the fenders should nicely mold right around the tire/wheel.
Please report back. I want to check the KBB values after you finish.
Site Moderator
Yeah thats the main one. I think the newer J's widebody is close and the M&M Honda kit is even wider. If you are going to do this why not get custom wheels that are 11 inches wide so you can at least fit a wide tire on there. 18x9.5 can be fit on a stock body S2000 with a roll and the right offset.
Back to the original question, I would say that those wheels specs would be too weak for those flares to look decent. As mentioned by Manga_Spawn, step up to at least 11" rear. I think HighwaystarDoritos is running a 13" +20 to give you an idea what can fit.
