18x9 +30 and 18x10 +38
Looking to pick up Work XD9's in the specs in the title. Will these be able to work on a stock body?
I am the following done:
All 4 fenders rolled & bumper tab relocation
-2 camber in the fronts / 0 toe
-2.6 camber in the rear / 1/16th toe
Any help would be greatly appreciated. Thanks!
No way, your a half inch too aggressive. You want a *50 in the rear and *45 up front in those widths to fit with rolled fenders hastle free with no rubbing. If you want to try stretching under sized tires and pull all your fenders then you could probably roll it, but I wouldn't.
I have the same width and offset in the rear and I needed -3.5 degrees of camber with a 255 tire to clear. I also had to get a full roll, tab relocate, and bumper trim. The front is 15mm more aggressive than I run and would need just as much camber if not more.
[attachment=54152:uploadfromtaptalk1392824272475.jp g]
This is my set up front is 17x8.5 +42 with - 2.0 and a 235 tire and it sits flush with the fender and 17x9.5 +38 with a 255 tire and - 2.5 camber and it pokes out about 1/2 in
