18x11 +15 315/30/18 r888 on 45mm widebody
I’m about install overfenders (cg fronts / j’s rear) both should give me about 45mm of extra width. I have a line on a set of Volk ze40’s in 18x11 +15 w/ 315/30/18 r888, looking at will they fit they will be 47.7mm wider than my current setup (17x10 +50, 255/40/17) since I’m coming from a fairly aggressive setup, I’m worried that it’s gonna require crazy camber & wont be worth it. My car lowered very mildly (less than 1”)
so fitment gurus, what say you?
I think you're about 15-20 mm over the limit up front unless you have 3+ degrees of negative camber and are running very stiff springs to keep the tire out of the fender. You're not going to be tucking the tire on compression with that fitment.
warbucks
Official "Official" Forum
03-17-2013 03:10 PM
