18X10 fitment question
Hey all just got new wheels for my ap2 the front it 18x8.5 rear is 18x10 i've seen plenty of s2k's fit 18x10's in the rear just wondering how hard it is to get the fitment down. I want to know if I will need adjustable control arms to pull some more camber to fit them, and what would be the best tire stretch im looking at only going 225, or 215 not sure which would be better but main questions is can an 18x10 fit on the s2000 rear with the small camber from the coilovers?
You can fit 11.5's in the rear if the offset is correct as well as tire size and the proper things are done to clearance the tires/wheels. We need to know the offset, offset is EVERYTHING.
Site Moderator
There are Volks that are 17x10 +70 offset that allow you to fun a 275 with no fender issues. But I am guessing from your tire size you have some crazy low offset in mind in which case
offset +25 sorry I didnt add that in the first place. but im trying to go flush and i'll stretch a 215 on it if needed to fit. Is it possible with that offset that i can tuck it with no fender damage with the stock camber?
