18x10 18x9 F/R?
#31
Originally Posted by s2000Junky' timestamp='1349371060' post='22059007
Aggressive. This is the work it takes if you want to do it right.
https://www.s2ki.com/s2000/topic/907...#entry21603174
#34
for a beastly look you need WIDE tires fyi.... 10-11" wide wheels with tires that are supposed to go on 7.5-8" rims do not look beastly one bit... and your car definitely will not have the same kind of performance it would with a proper fitting setup.
to each his own though
#35
for a beastly look you need WIDE tires fyi.... 10-11" wide wheels with tires that are supposed to go on 7.5-8" rims does not look beastly one bit... and your car definitely will not have the same kind of performance it would with a proper fitting setup.
