18 x 9 +53 offset in the rear
Old 07-31-2005, 11:13 AM
Former Sponsor
GoTuningTommy's Avatar
Default 18 x 9 +53 offset in the rear
Hey guys,
I'm planning on going with a 255/35/18 tire size on a 18 x 9 +53 offset in the rear...will it fit?
Thanks!
Old 07-31-2005, 04:04 PM
SIIK2NR's Avatar
Yes it will fit.... 9" wide rim with +53 should still "tuck" if your dropped pending the sidewall of the 255's.....
Which tires are you going to run?...
Old 07-31-2005, 04:26 PM
Wildncrazy's Avatar
If you run skinny tires it will.
63 offset with wide tires rubs.
Old 07-31-2005, 04:29 PM
SIIK2NR's Avatar
Please check your facts..... you need to define "wide".... 255's will NOT rub on a +63 offset.
The question is regarding +53....
Old 07-31-2005, 04:52 PM
Former Sponsor
The subject to whether a +63 offset will not rub.
Old 07-31-2005, 04:53 PM
Former Sponsor
Awesome! I'm running the new Toyo T1R. Will that be ok?
Old 07-31-2005, 04:58 PM
Wildncrazy's Avatar
I have checked my facts with first hand knowledge! 255 BFG KDs rub even with grinding down the the screw that holds the liner in.
S02s (10" wide) rub as well. Quite a bit more than just little!
If you buy one of the tires that is narrow for it's rated size you might get away with it but if you have a tire that is full width or more then you'll rub
Old 08-01-2005, 01:11 PM
Former Sponsor
ANYONE ELSE?
Old 08-01-2005, 01:47 PM
ahbongkadah's Avatar
new rims? Will you be selling your wedsports
Old 08-01-2005, 01:50 PM
Former Sponsor
I sold them a long time ago...sorry!
Quick Reply: 18 x 9 +53 offset in the rear
