18 x 8.5 +50 offset
I would do 245-35, since it is the correct size for 8.5", shouldn't rub, and is stock diameter. However, not as many tires are available.
235-40 and 255-35 (possible rubbing) are your practical limits.
Good luck
Good luck
Originally Posted by r_duff,Nov 4 2004, 07:33 PM
I think that would look quite silly. I have a 245/35 on my rear 8.5 wheel, although most ppl use 255/35 on an 8.5
I'm running 245/35/18 on rears and 225/40/18 on fronts.(toyo T-1s)
18x8.0 on rears(+48 offset) 18x7.5 on fronts(+50 off set)
lowered 15mm(1/2"). no rubbing issues.
