18" Tire Fitment
18" Tire Fitment
Hi new here. I have buddy selling rpf1's 18X10.5 +15 offset for all 4 wheels. Is there anyway this could work if my car isn't lowered? Will it throw the handling off enough to make it hard to steer? Any input would be helpful.
Those wheels will stock out 30-50mm too much. They won't come close to fitting even if you has the standard +25mm asm flares and the typical +30mm downforce front fenders. they might work if you go with the rocket bunny +75mm fender flares.
If your on a stock body and you want 10.5 inch wide rims you need sometime that +50 to +60 off set for the rear. And I'm pretty sure a 10 inch rim is as wide as you can go for the front and it needs to be a +50 to+55 for the front. You can get away with a 10 inch rim and +40 to+50 if you have the 30mm wider downforce front fenders.
if you still want them to fit you can always ruin your car by standing out the car by running -5 degrees of camber and stretching a 215 size tire on your 10.5 wide rims.
