18 inch, HKS springs and rubbing
Anyone here with 18 inch wheels and HKS springs rubbing their fenders ? Got Work Meister S2R wheels...normally perfect fit...
Thanks a lot !
DOHC
Thanks a lot !
DOHC
Not sure yet if this is going to work, as my car is in the shop as we speak, but I am having Koni adjustables, with Ground Control adjustable coil over springs installed. I went this route because the height can be stock, or lower if you wish. I have calculated that a fender roll will be necessary, but I am running 265 in the rear, you may be fine with 255. One downside to rolling the fender, you can't roll all of it. The place where the rear bumber meets the feder is reinforced, and will not bend.
BerlinaBlackS2kguy
03-15-2007 05:14 PM
