17x9+63/Spoon/OEM/Stock fender
Old 03-14-2007, 09:47 AM
jsdude's Avatar
Default 17x9+63/Spoon/OEM/Stock fender
I have been searching about this question i want to ask, but i can just never find the answer i want. so here is the question
1. 17x9+63 will clear spoon caliper AND will be able to run on STOCK FRONT FENDER with 245/40-45/17?
I know it will clear spoon caliper but i got to ask this way
2. If so, why does the amuse AP1 model car need a custom front fender roll or pull?
3.What MM of spacer needed for 04-05 OEM wheel to clear spoon caliper? or it can never happen
4.Whenever using a spacer more than 5mm, how will the steering react on the track?
5.What is the color code of the takata green on the CE28n?
Old 03-14-2007, 10:23 AM
innovation's Avatar
i've searched myself and found 17x9 +54 will clear spoon caliper and i think +63 wont clear the caliper
Old 03-14-2007, 01:46 PM
jsdude's Avatar
but the problem is can it run 245/45-40/17 with stock fender in the same time
Old 03-14-2007, 06:05 PM
BSeriouS's Avatar
You need at least a 17x9 +54 to run the spoon caliper up front. That or run a +63 and run a 10mm spacer up front. By the way it looks, it is doable by running a 245 but your gonna have to run some aggressive negative camber to run this size, caliper, tire setup.
I've even seen a 9 +45 RPF1 with a 255 all around, but he still has some slight rubbing with an aggressive camber. Looks hot though
Old 03-14-2007, 06:26 PM
jsdude's Avatar
9+45 RPF1 without fender change? the main point is i don't want to do an aggressive camber
and it's has been like 7 hours since i post this topic, and still no one can really answer my question? I thought there's many pros over this board
Old 03-14-2007, 06:28 PM
innovation's Avatar
on stock height i was once told i can fit 245/40 tire with no rubbing
Old 03-14-2007, 09:14 PM
trustbran's Avatar
Why not try just running a 235 or 225 up front....
Old 03-14-2007, 09:19 PM
jsdude's Avatar
i have been running 225 in the front for over 2 years, and now i want a new change
but it's really no one knows the answer?
Old 03-14-2007, 09:25 PM
trustbran's Avatar
so you had no rubbing issues on the 17x9 with 225 without changing camber or rolling fender??? I am thinkin of running 225 or 235 on 17x9 without fender rolling or changing camber but at the same time I don't want the rim to stick out so bad.....
Old 03-14-2007, 11:31 PM
jsdude's Avatar
the prolbem is can 245 with -2.0 camber WITHOUT rolling fender works
Quick Reply: 17x9+63/Spoon/OEM/Stock fender
