17x9.5 +38 w/ 255/40/17 X4
Old 09-09-2010 | 06:53 AM
  #31
Boost76's Avatar
Best I found to work with my setup was 215/45/17 up front & 235/40/17 in rear, but to each their own. Bigger tires mean more neg camber. I found that when I ran 245/40/17s they where to big & & I had to run more neg camber than 235/40/17s. If you don't track much then just get smaller tires. Plus, its not like the S2 has enough torque to turn those bigfoot tires. haha
Old 09-09-2010 | 02:45 PM
  #32
dat boi's Avatar
Originally Posted by james0933,Sep 8 2010, 01:16 PM
What if you want to go back?
Buy some stock fenders
Old 09-09-2010 | 09:30 PM
  #33
Muscle Cars Blow's Avatar
is the rim being a 9.5 the issue? Or is that offset it?
Old 09-09-2010 | 11:05 PM
  #34
Jphoa's Avatar
In most cases, width of the rim has little to do with whats causes the problem. A lower offset is what you should be more concerned about, which is what is making all the calculations difficult. You can easily run a 9.5" wide wheel w/o fender modifications if the offset is at or higher than +60 (ball park number); but than tire size has some play in this as well.
Old 09-09-2010 | 11:11 PM
  #35
What I figured. Hell on my gto I can't even fit 9.5's without cutting the fenders. And it's a freakin v8. Amazing you can on such a tiny car.
Old 09-09-2010 | 11:44 PM
  #36
dat boi's Avatar
People on the Racing forum that autocross their car have ran 10s all around. Which is very amazing for a car with stock body and no modifications to suspension components to clear. Not many cars car run that rear let alone the front
hellspare
04-18-2011 11:09 AM
DTP525
06-05-2010 04:26 PM
shoes59
01-09-2010 11:57 AM
ericbarber
11-19-2009 12:21 PM
sillyboybmxer
01-22-2008 03:08 PM
Quick Reply: 17x9.5 +38 w/ 255/40/17 X4
