17x9 +45 rpf1
17x9 +45 rpf1
Hi,
I was looking to get 17x9 +45 rpf1s all around with 225/45/17 in the front and 255/40/17 in the rear. I was planning to put on some eibach pro kit springs as well. Is this set up optimal and will I need to do anything further then roll the fenders?
Thanks
Thanks
No. It will rub for sure any time you hit a bump or take a corner aggressively though so it should only be a temporary solution. A fender roll will take care of any rubbing issues even when lowered.
235/40-17 might be a better tire size choice up front for 9" wheels. Probably no more likely less due to being 1/2" shorter than 225/45-17. Fender rolling probably required either way.
For the rear a 255 will be fine with a roll and a relocation the bumper tab. No pulling is needed. -2 camber should be good as well. I can't tell you about the fronts because I am not familiar with it.
