17x9 45 offset with 245 tires for the front
Hi all,
I'm planning to get RPF1 17x9 45 offset all around, but instead of running 255/40/17 for 4 corners I'm planning to run 245. Anyone can give me some advice on what needs to be done for the front fenders? I checked wheel fitment guide the rear should be no problem, but for the front I assume fender rolling is required for this setup, but do I need to flare the front fenders as well? or any other modification for the front fenders?
Appreciate for the help
Originally Posted by rioyellows2k,Nov 14 2009, 10:36 AM
You'll only need to Roll the fronts, and maybe trim the Fender Liner a little. Flaring shouldn't be involved unless your vehicle is slammed.
Originally Posted by B18C5-Eg6,Nov 16 2009, 09:21 AM
this would work with just a rolled front fender depending on how low you are.. but u gotta be careful with going to drive ways and not turn the wheel
I learned this the hard way and pwned my passenger side fender.
Originally Posted by soozookabluS2k,Nov 17 2009, 01:52 AM
quick question.. a 17x8 +45 and a 17x9 +45 and both have 225 tires..how much more would the 17x9 stick out on the front
[QUOTE]this would work with just a rolled front fender depending on how low you are.. but u gotta be careful with going to drive ways and not turn the wheel
Sorry, just want to clarify that u mean when I'm on a driveway I shouldn't turn my wheel to avoid rubbing or hitting the front fenders? Is there any problem when I turn my wheel during regular driving? I'm planning to lowered my car about 1.5 finger gap will that be okay?
Thanks all..
Thanks all..
garykoo
04-29-2017 06:35 AM
