17x9 +38
17x9 +38
Planning on doing this setup with a 245 all around what kind of camber should I be running with about a finger gap all the way around? I was thinking -2.75 neg front and -3.0 neg rear. If you guys are non-staggered what kind of alignment specs should I be running? I plan on doing auto-x.
+48 would be a better choice
I am currently fitting 17x9 ET35 with 245 rear and 235 front.
having my alignment tomorrow so will be able to let you know then, for now i have rolled and flaired the front fenders and rolled the rears flat.
Someone local in the Bay is running that size on RPF 1 wheels with RS3 in 255/40. He had to do the usual fender work:
1. Pull front fenders as far as you can using either a roller or go to a body shop, trim the fender liner
2. Roll the rears flat with slight pull, relocate the mounting tab back & trim the arch on the rear bumper
3. Run static camber as high as you can/desire - reduce toe if you can in the rear.
Since you are running 245s, you should have better clearance over a 255/40.
FromaDB2toanAP1
10-23-2012 10:19 PM
