17x9 +35 stock fenders?
I had 17x9 +45 w/255 all around... don't think it's possible to have stock fender work. I had to roll the rear and relocate the tab for the rear. I also had to shave parts of the rear bumper. The front was also slightly pulled.
Perhaps if you had a ridiculous amount of negative camber, but other than that I don't think you can fit 17x9 +35 w/o fender adjustments. Or of course if you are 4x4 status.
It's possible. Check out this thread. It has lots of pictures for reference. https://www.s2ki.com/s2000/topic/846...rey-pearl-ap1/
It's possible. Check out this thread. It has lots of pictures for reference. https://www.s2ki.com/...grey-pearl-ap1/
"hired someone to do the bodywork on her (sand and prep, fix dents, fill some holes, flare front and rear fenders)"
bolded emphasis mine. just FYI.
i have 17x9 +45's and lowered to 1 finger gap on all 4 corners. you need fender work period or just enjoy the 4x4 look.
I run 17x9x4 with a +42 offset in front and +35 in the rear with 255 tires on all 4 corners. -4 camber rear and -1.8 front fenders rolled, bumper bolt moved and bumper trimmed. No pull and no flare I have very minor rubbing in the front. none at all in the rear.
How stiff are your springs?
